Burning Rubber Smeel Coming from Wheel Well
Old Jun 19, 2006 | 05:44 PM
BurnOut's Avatar
Burning Rubber Smell Coming from Wheel Well
I have a burning rubber smell coming from my rear left wheel well after I drive my 240 for a little amount of time. I dont know if the oem muffler I just got plays a role in this but I can definetly smell the rubber smell. I took it to the mechanic today and he says it could be the clutch. I don't want to spend tons of money just to CHECK if its the clutch when the clutch seems to be working fine. I forgot to mention that the smell was coming from the wheel well to the mechanic. Does anyone know what may be causing this??? I am guessing either the brakes or the muffler may be playing a role. The only new part is the muffler though and it does not smell like oil.
I would appreciate any help from you guys if anyone has any ideas. Thanks alot.
Sincerely John
Old Jun 23, 2006 | 10:32 PM
Levi SPL S14's Avatar
Umm jack up your car and see if the tire is hitting or rubbing on anything. Tires with real low PSI will start to burn since now your driving on the side wall.
Old Jun 24, 2006 | 06:47 AM
also check your pads/rotor maybe the brake is seized up or rubbing and the smell is brakes on fire.
Old Jun 24, 2006 | 10:36 PM
g3bio's Avatar
if your car is to low ie. coilovers, your problem might be with rubbing against the coils and rotation of the wheel is causing rubs.
Old Jul 8, 2006 | 11:47 AM
Badazz_240's Avatar
I agree.... My best guess is that you are rubbing on something (most likely wheelwell or strut/spring) or you are just accelerating a little too hard
Also, if you dont know what clutch smells like, its along the lines of a weak rotten egg smell
Give your brakes a check, and if your clutch starts slipping then look into that as well.
Old Aug 4, 2006 | 08:53 AM
positron's Avatar
Re: Burning Rubber Smell Coming from Wheel Well
Sincerely John
When that happened to me it was because my tires were too wide/big and were rubbing on the struts/fender well.
Biggamehit
Sep 10, 2007 07:35 PM
Kami Speed
Jul 14, 2007 08:34 AM
chuck240
Jul 27, 2005 04:30 PM
budfoxx
Jun 21, 2005 08:11 PM
leiferik1
Mar 28, 2003 05:12 PM
