Busy weekend....
Busy weekend....
I have a busy weekend ahead,with z32 brake conversion(front and rear alu 30mm calipers, master cyl, booster, and braided steel lines), spl tc rods, whiteline front and rear sway bars,NISMO front power brace,Nissan Motorsports strut bars(frt & rr), Eibach sportline springs,and KYB agx struts,with an alignment!!
Anythig else I can do under the car while I'm there!!
go to h*ll!!
just kidding, Thats a nice setup... almost all the same stuff i'm planning on doing. Lemme know how you like those whitelines
and the power brace... i dunno whatelse you can do really, clean **** and check around that everything is cool.
wow wow wow. two weekends ago i did tension rods, tie rods inner and outer and boot, toe and forward and ruca, coilovers, fr and rear strutbars. i wish i could do the brakes and the power bar. i have those on my list to do.
you should have gone with coilovers though but that is a lot of work and money.
clutch damper removal since you're under there - http://garage.projectraine.com knock yourself out for about 5 minutes
mr2monster
Jun 1, 2003 02:54 PM
