Camber Question
Old Jul 28, 2006 | 01:23 PM
JDMxDrift's Avatar
Camber Question
So I got a little collision on the front driver side fender area. Suspension took some damage (tension rod, Tie Rod, LCA, and coilver). I've replaced tension rod, LCA, and put the stock suspension on with tein S-techs. However i'm still getting some camber on that wheel. The camber plate on my silks was a little bent as well as the lower perch mounting holes were stretched. Is there any other points in the front suspension that adjust camber? The only other things i can think of are that the spindle is bent (hard to believe since they are casted iron or something hard, at least i hope its not the spindle) or its the upper strut tower mounts are out of place (which sucks too). Should i check any other places?
redpotatoes
Jul 23, 2006 11:52 AM
SD240619
Jun 26, 2006 05:48 PM
jspaeth
Apr 2, 2006 10:01 PM
KeN VeRsUs RyU
Apr 30, 2005 03:21 PM
positron
Dec 18, 2002 05:25 AM
