do I need to get camber kit for S- Tech + GR2?
Old Dec 30, 2004 | 02:22 PM
ArticDragon's Avatar
I believe camber plates give more adjustablity than camber bolts. And no, hood will still close. You want a new adjustable RUCA to adjust the camber settings. As far as the other questions... not sure, so someone else will chime in with soem answers.
Old Dec 30, 2004 | 03:05 PM
Originally posted by twofotisx
1. Why buy camber plates if you can use adjustment bolts for the front for like $10 bucks instead of $100 for the camber plates? Do the Camber plates interfear with closing the hood because of their elevated height?
2. Why do you need to buy a new Rear Upper Control Arm (if is what RUCA stands for)? Is this in addition to the camber plates for the rear? Also I remember seeing somewhere on this site that you can adjust the rear without any extra parts. Is this true?
3. How easy is it to adjust these camber plates and know what degree that you have them adjusted to? I know that in autocrossing a negative camber is desired because it increases the handeling abilitys of the car. So could I theoritically adjust these camber plates before a meet so and then adjust them back afterwords so I wouldn't get bad tire wear?
I'd really appreciate any help or info. given for any of the questions. THANKS!!!
since twofotisx specifically requested my presence in this thread (lol):
1. Camber plates for the front give you much more adjustment than camber bolts. Camber bolts only give like +/- 1 degree, whereas camber plates allow ALOT more. Also, camber plates incorporate a pillowball mount in the center in place of the factory rubber bushing and flat bearing. When installing camber plates, they go under the shock mount, so they don't interfere with the hood. However, depending on brand, some camber plates are thicker than the stock upper mount they replace - so it might raise the front of your car a little (.25" or so)
2. Yes, RUCA = Rear Upper Control Arm. First of all, you can adust rear camber in the rear using the inside bolt on the stock RUCA - it's a factory adjustment, but it only gives about 1-1.5 degrees of allowance. Just like with camber plates up front, when you install adjustable rear arms, you get a larger camber adjustment range, plus pillowball mounts in place of the factory rubber bushing. There is no rear camber plates for 240SX - if you look at the rear suspension, moving the mounting point of the rear shock from the top will not alter the wheel angle, as opposed to the front where the wheel is directly attached to the shock itself.
3. Well, I have front camber plates (Tein Flex), front camber bolts, rear adjustanle control arms, and (of course) the OEM rear camber bolts. The front camber plates are easy to adjust - loosen 4 bolts up top, and you can change the front camber. For the rear, you have to get under the car and adjust the RUCAs with 2 wrenches, which isn't hard except for the fact that you can't adjust it without getting under there.
As far as what to adjust them to - take your car to a good alignment place, have them set the car to factory specs. Record the settings, then you can play with camber all you want.
Old Dec 30, 2004 | 03:39 PM
RS13's Avatar
I have S-Techs and AGX shock and i only got an allingment. i have 1.5 degress or camber up front and 1.7 in the back. no cam bolts or eccentric bushings. it all depends on your car. it really messed up my toe in the back so get an allingment done. i had 1.9 degress of toe in on one side and .25 degrees out on the other. great combo tho
Old Dec 30, 2004 | 04:39 PM
S13 FSM spec is 0-1.1 degrees front camber , 0.1-1.1 degrees rear camber. 1.5-1.7 isn't bad as long as you got the toe right, and you rotate the tires frequently. I think it all depends more on the driver and their willingness to maintain their car more than anything
Old Dec 30, 2004 | 10:39 PM
RS13's Avatar
its not bad at all on tire wear. i've been using the same Kumho 712 for 3 seasons and have over 50 XXX kms on them. it shows even wear across the whole tire so i'm happy. like Raine said it all depends on your driving style. it is also a good starting point for autocross too
Old Dec 31, 2004 | 05:22 AM
twofotisx's Avatar
sweet, thanks for the info, I wanted to hear l2aine say it because he seems really knowledgable about all things 240. At lets face it he owns snickersgirl's boob. Who the hell else would i ask?
Old Dec 31, 2004 | 05:42 AM
I own both ROFL ahaha I can't believe that subject bled over to this thread LOL
Old Apr 30, 2005 | 08:56 AM
kang128's Avatar
hey how come i can't find RUCAs for the s13
i know they are on other sites but i cannot find them cheap on ebay ....whats going on?
if anything should i go for pdm's rear camber kit or the RUCAs they have for rear camber
Old Apr 30, 2005 | 11:43 AM
If you don't plan on upgrading to coilovers or going lower than 1.5", the the PDM kit might be ehough - but IMO it's kind of pricey for what you get. I'd still go for the RUCAS instead (as for Ebay, give it a few days, they'll show up again in the listings)
Old Apr 30, 2005 | 12:20 PM
DriftOrDieTryin's Avatar
that was my rear tire after about 1000 miles and some drifting
i bought adjustable RUCA's on ebay for 120$
Old Apr 30, 2005 | 12:30 PM
  #26
jackyliem's Avatar
well happen to be I have 1.5 to 2 degree camber at the back and only around 1.5 in the front. I am using the ZEIX 512 with 460 trandware so I guess I will be happy will my current setup
Old Apr 30, 2005 | 12:56 PM
  #27
IIRC the allowed range from the factory spec is between 1.0-1.3ish... but if your toe settings are corrected, then 1.5 shouldn't wear your tires as bad
Old Apr 30, 2005 | 01:06 PM
  #28
jackyliem's Avatar
yea I did made do the alignment and my toe are right
Old Apr 30, 2005 | 01:23 PM
  #29
col then the only thing you have to worry about is how hard you drive
Old Apr 30, 2005 | 01:43 PM
  #30
kang128's Avatar
there is none!!...i even checked completed listings
man i saw them a long time ago and now they're gone
well i ordered my kyb agx and s-techs
what else do i need...this is my list so far
springs
shocks
RUCAs
pdm-racing front camber bolts (28$$)
thats it......should i get the toe rods>? or can i adjust it using the factory
