E-Brake removal
E-Brake removal
I need to know if there is a way to remove my ebrake cables without cutting them. The problem is I can't get the wheels off (locking lug nuts without the key)
I'm sorry if there is a recent thread, I looked some and searched and didn't find anything
Sure.
You can disconnect the ebrake cable from the rear caliper here. I can't remember the size of the bolt but you take it out and this bracket comes off the caliper.
You can take the ebrake cable out of the bracket now.
For the other end you need a screwdriver, turn the ebrake cable 45 degrees and use the screwdriver to pop it out of the t-bracket and you can remove the cables.
jdmsoarer
Apr 17, 2004 10:59 AM
jdmsoarer
Apr 6, 2004 05:56 PM
SlydeSHO
Jan 22, 2004 04:20 AM
