brake line removal problem!!!! help please
Old Jul 1, 2006 | 05:42 PM
Christpher's Avatar
i bought the flare 10mm wrench like the service manual said for my 96 240sx. and when i go to remove the upper flare fitting, the wrench is rounding the sides. so what am i suppost to use to remove my brake lines so i can put the new stainless steel brake lines in. this is holding back my partial brake upgrade which includes new brembo rotors, axxis ultimate pads, and goodridge brake lines... so if you can give me any guidance on how to handle this problem it would be much appreciated.
thanks
christopher
props to the 240
Old Jul 5, 2006 | 04:56 PM
Christpher's Avatar
i guess nobody has the same problems as me?
for 20 people to look and say nothing!
**** it...
Old Jul 5, 2006 | 07:21 PM
Black240Coupe's Avatar
did u spray it with rust penetrant??...if that doesnt work ure gonna need to get a hardline...which cost a pretty penny.....i was gonna change my lines but when i saw them rusted shut i gave up..
Old Jul 6, 2006 | 07:09 PM
Christpher's Avatar
that sucks, i sure appreciate you letting me know that...
i've been sitting here wondering if i should just forget it and install the rotors and pads? i guess i will probably take it to a nissan mechanic and ask them or judst forget the lines. this sucks.
Old Jul 6, 2006 | 07:10 PM
Christpher's Avatar
but yes we did spray them. then waited. then used the flare 10mm wrench and the sides were rounding out.
Christpher
Oct 8, 2005 04:50 PM
breakindrifts
May 10, 2005 02:12 AM
japporeyser
Apr 7, 2004 08:15 PM
SlydeSHO
Jan 22, 2004 04:20 AM
shleevo
May 31, 2003 02:17 PM
