HICAS conversion
HICAS conversion
I've been thinking a lot about this. Can someone convert and non-HICAS car to HICAS. True, the HICAS system hinders drifting abilities, but from what I can tell, it helps with gripping and since this is the style of driving I'll be doing in my Fastback, I figured having HICAS would be benificial. So... is it possible and if it is, is it expensive and worth it?
Anything can be done.
Get all the HICAS parts from a HICAS car(how youw ill find one is another story)
The Pump, lines, sensors(I think it has special ones), full rear suspension and I think it has a special ecu.
How much money or time it will take to swap all that sht in your car, don't have a clue!
Would it be worth the trouble. Sure, it'll be unice since it's a HICAS conversion, but will it be worth the trouble? Will it make that much of a difference in handling?
How bout you try and find someone that has a super HICAS 240 and drive it.
Good idea. The only thing though is that I heard that HICAS is unpredictable to a driver not used to it. But I fugure you can tear uyp the touge if you can harness the potential of 4-wheel-steering.
