hub question???
hub question???
Can someone tell me if s13 hubs will fit on a s14, the reason i am asking this is because someone i know has some new curcuit sports hubs for sale. but all the sites i look on says nothing about them fitting on the front of the s14. i have been searching fort This answer and can't find it any where. i do have a base model s14...
s14 stuff will fit on s13, but only some s13 things will fit on s14, if you wanted to put the s13 front spindle on a s14 i don't think it's ganna to fit. only b/c you need the s13 spindle to put the front hubs on
what about just removing the s13 bearings and changing out with s14 bearings. that should work i would think,or is there something else differant about the s13 and 14 hubs besides the inside diamiter of the bearings..any more idea's. thanks everyone.
ok.. so the s14 4 lug spindle is the same as the 5 lug spindle? i guess i'll just have to buy 2 se front hubs, and change out the studs for the extended ones from the curcuit sports hubs since the rear already works...
