Noisy Spring????
Old Sep 15, 2007 | 12:38 AM
positron's Avatar
Noisy Spring????
Recently I've been hearing a creaking sound from the left drivers side of my car. I can hear it sometimes when I get in and out of the car and sometimes when I get down and pull on the rim. I've jacked the car up and checked for loose connections on all my suspension and struts and found nothing. The only thing I can think of is a noisy spring? Can anyone chime in on this. I hate not knowing where this is coming from. Or should I just lose 20lbs. off my fat@$$!!!!
Old Sep 15, 2007 | 09:54 AM
it sounds like it's just the coils. it's quite common, click on the link about 3/4 of the way down you'll see the solution.
http://www.pdm-racing.com/products/suspension.html
Old Sep 15, 2007 | 01:14 PM
positron's Avatar
You know, I've been reading about those things on that site for years and never put two and two together. I think you just solved my problem...thanks!!!!
Old Sep 15, 2007 | 01:19 PM
always happy to help.
Old Sep 15, 2007 | 04:00 PM
neville610135's Avatar
on a similar issue, mine are noisy, but they sound like they are bottoming out. is that the same noise? its not a creak more like a bump
Old Sep 15, 2007 | 04:17 PM
probably not, your problem is more likely a bad shock or strut.
Old Oct 4, 2007 | 04:01 PM
positron's Avatar
I pulled the strut assembly and found that the rubber insolater had come loose from the top mount so I put it back on as snug as possible and the noise is practically gone. I can still hear it sometimes but I think it's because that rubber isolater is in such bad condition. I think I'll get some new ones or some camber plates.
Old Oct 4, 2007 | 04:31 PM
i thought you were talking about the front.
ryan15
Mar 7, 2004 11:18 PM
altima/240sx
Dec 31, 2002 03:49 PM
spitz7985
Dec 14, 2002 10:11 AM
spitz7985
Sep 5, 2002 10:19 PM
RNN14
Apr 30, 2002 10:06 PM
