installing stock front struts?
Old Apr 23, 2005 | 12:24 PM
sicow's Avatar
Angry installing stock front struts?
i'm having trouble installing the stock struts back into the vehicle.
we've used a spring compressor to shorten it but the trouble is taking out the compresser when installing the two bolts that hold the strut...
is there another way of installing the stock struts?
btw its stock struts with stock springs.
Old Apr 24, 2005 | 01:25 AM
sicow's Avatar
anybody??
Old Apr 24, 2005 | 01:34 AM
lrb_2000's Avatar
you should be able to put together the shock/springs as one... and then you just put them back under there... you should explain it again.
Old Apr 24, 2005 | 08:51 PM
sicow's Avatar
thanks for the reply.
oh ok, let me rephrase myself.
i am taking out my coilovers and putting back my stock struts on my car. i have not taken apart the stock struts so the shock/spring is still together but my problem lies with connecting it to the rotor.
the stock shocks are really long because the spring isn't compressed. and when we tried the spring compresser to shorten it our prolems is taking out the spring compressor while the shock is under the fender.
i dunno if im missing something or if there was a easier way of putting stock shocks back.. its so much easier putting on coilovers or shocks with lowering springs
Old Apr 26, 2005 | 01:05 AM
lrb_2000's Avatar
I don't understand... umm it should all go together before you even try to put it back under the car... you should be able to compress the spring, put on the top plate, bolt down the top nut, and remove the compressor... then it all goes in as one piece... the spring compressor shouldn't even have to get close to the car.
go here, it's pretty much the same thing.
http://www.nissanperformancemag.com/...spension.shtml
note: make sure to use internet explorer
Old Apr 26, 2005 | 01:23 PM
sicow's Avatar
hey that helps thanks.
Old Apr 30, 2005 | 12:23 PM
maybe you're doing one corner up at a time (i.e. floor jack speshal) and your sway is pushing the raised arm higher, making it look like it's way off.
use some muscle, you can align the fronts so easy.
Old Apr 30, 2005 | 03:06 PM
sicow's Avatar
yeah that was the problem.. its fix thanks.
Old Apr 30, 2005 | 03:15 PM
Levi SPL S14's Avatar
^ new i was about to say that.
slipperypanda
14
Aug 20, 2007 06:22 PM
Hybrid22l
Aug 15, 2006 09:20 PM
Magius360
Feb 2, 2006 11:58 PM
ryan15
Jan 19, 2004 04:15 AM
