low budget shocks and spring.
Old Aug 10, 2004 | 12:52 AM
jackyliem's Avatar
hi I have a 1990 240sx and I am still running on the old stock suspension. I am wonder how big is the difference in spec (not price) between tokico blue shock, and KYB BS-2. And should I get Tein S. tech or Tanabe GF210 for spring? since I only have a low budget. do you guys think it's ok to get non adjustable shocks or should I really save up for adjustable?
thx
Old Aug 10, 2004 | 03:37 PM
swannjay's Avatar
the KYB Buzz Spec adj. shocks never made it to the states. But, they're pretty much the same thing as AGX from what I heard.
Japan - Buzz Spec. US - AGX. = both the same thing.(pretty much)
Don't buy non-adj shocks and springs. I have Sprint springs (good) on GR-2s (bad). The GR2 blew after about...5 months. S-tech or GF210s are a good choice for springs but, save up for some AGXs. I've seen them on ebay for as low as $300.
If your dead set on non-adj shocks, try the Tokico Blues. I haven't heard much bad about them yet.
Old Aug 11, 2004 | 01:23 AM
jackyliem's Avatar
is kyb GR-2 any good?
Old Aug 11, 2004 | 01:28 AM
GR-2s work fine as long as 1) you don't use springs that go lower than 1", and 2) you don't drive really REALLY hard.
I had a set of GR-2's and Tein S-Techs and they did good on the mountains but a little soft (compared to AGX and Tein HE's)
Old Aug 13, 2004 | 07:55 PM
1995 240sx's Avatar
with the agx springs were whould they be set hardness wise so that they will not blow out from lowering springs?
Old Aug 14, 2004 | 01:01 PM
AGX are the shocks, not the springs, and they were designed to work with lowering springs, unlike stocks which usually blow out in little time
Old Aug 28, 2004 | 01:55 AM
sprung_monkey's Avatar
sorry to bring up an old topic but i had somthing to ask insted of starting somthing else
i am buying the h-techs for a 93 se and just wanted to know how those with some agx would work?
Old Aug 29, 2004 | 01:18 AM
H-Techs are barely stiffer than stock springs, and barely lower the car. They'll probably work with AGX at a softer damper setting, but IMO the H-Techs are better suited to GR-2's or Tokico Blue
Old Aug 30, 2004 | 09:40 AM
so would the s-techs work better??? i dont want it slammed in the weeds but i want something a little lower
Old Aug 30, 2004 | 02:39 PM
ArticDragon's Avatar
S-techs drop a little lower tha 1 inch. Isn't too much of a drop if you ask me.
Old Aug 30, 2004 | 02:49 PM
yeah if you didn't know it had S-Techs, you might not notice it on a car
jackyliem
Mar 1, 2006 05:02 PM
evanr_240
Jul 17, 2005 02:27 PM
haipho123
Jun 12, 2004 10:02 PM
Sil80guy
Feb 24, 2004 09:42 PM
evilsil
Dec 18, 2003 10:02 AM
