Megan Racing vs Apexi N1 coilovers
Megan Racing vs Apexi N1 coilovers THE TRUTH NOW
Edit by Raine:
People pay attention:
Apex-i and Megan coilovers are NOT the same.
Please see the last post in this thread.
BELOW IS THE ORIGINAL POST IN IT'S ENTIRETY (minus the photos):
PROVEN FALSE:
It's time to let the cat out of the bag...
I have said the MR coilovers are resold by several brands, and rebadged by many of the JDM brands...
I'll let you guys put 2 and 2 together...
Apexi N1 coilovers: $1300
MR's: $900
Saving $400 on the same coilover: Priceless.....
PROVEN FALSE:
MR's: $900
Originally posted by underground
Trust me 80% of the Japanese parts are made in China/Taiwan/S.Korea... I can assure you...
Originally posted by JDMxDrift
So all the little pieces are manufactured by 6 yr. old kids in china then shipped to Japan for assembly, then shipped to america for a 1000% mark up?
Re: Megan Racing vs Apexi N1 coilovers
[B]It's time to let the cat out of the bag...
Apexi N1 coilovers: $2500
MR's: $900
Saving $1600 on the same coilover: Priceless.....
MR's: $900
Originally posted by Catharsis
uhh he megan racing coilovers say apexi n1 all over them
In response to what I think you're asking, Megan denies the rumor which claims a connection between the Apexi ExV and the Megan Coilovers.
They do look alike but where you get the $2500 price I don't know. I found them for $1189. Here is a compersion of the specs
- Full Coil Over Threaded Base
- Monotube Shock Absorber utilizing a 44mm diameter piston
- 32 level damping adjustment
- 62 mm direct wound spring
- Piston diameter is 44mm
- Front springs rate is 8k and rear springs rate is 6k
- 22mm Strut type rod (All others use a 12.5 mm rod)
- Quick Adjuster, Coil Over Adjustment Wrench included
- Exclusive Upper Mounts
- Aluminum Brackets (Strut utilizes steel brackets)
- One Year Warranty for (Oil, Gas)
Megan Racing
- Spring Rates: 8kg Front and 6kg Rear
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cyliner Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
Not bad for an entry level coil-over but at a $200 I might go withthe Apexis just becuase they are a trusted brand.
heres a pic ofthe megans to compare
Megan Racing
- Aluminum Brackets
