Need camber help ASAP
Old Aug 7, 2006 | 02:33 PM
2plus4plus0EQ6's Avatar
I currently have some tanabe s-oc type II on back order. I am getting some 17s put on with it. I think the coilovers come with rubber upper mounts.
So I need someone to clear some stuff up for me..
rubber upper mount = non adjustable??
pillowball upper mounts = camber adjustable?
because my coilovers are going to be using rubber upper mounts (which i want for daily driving), is the only way to adjust the camber is to put on some camber arms and tension rods?
thanks
Old Aug 8, 2006 | 01:25 PM
Levi SPL S14's Avatar
soc usually doesnt have camber adjustment on the top mount, you usually have to use your stock stuffs.
pillow ball does not mean its camber adjustable. it just comes with nice mount w/ pillow ball
Old Aug 8, 2006 | 03:51 PM
jspaeth's Avatar
the tein pillowball uppermounts have camber plates in em if you want that adjustability there
Old Aug 8, 2006 | 04:48 PM
well im thinking i will use the rubber upper mounts that the s-oc comes with.. i hope it comes with it!!!!
cause im looking for ride comfort.
i want a -1 or -2 camber.
would i need to change my camber arm or tension rod.. or any of that stuff?
Thanks
jspaeth
Apr 2, 2006 10:01 PM
jackyliem
33
May 2, 2005 02:07 AM
jksstar
Jun 20, 2004 11:38 AM
skillzilla
Feb 8, 2004 09:08 PM
Ray240CA18
Sep 11, 2003 09:16 PM
