rear brakes
Old Aug 28, 2004 | 08:44 PM
konichagwa's Avatar
Post rear brakes
I just got my first 240sx, its a 95 model. I have all the stuff to do the 300zx break change over, Its already done in the front. In the meantime I have to change the rear breaks. I have the old breaks off and was pressing the calipers back in when they just stopped. I broke one C-clamp trying to press them in, is there a trick to getting them pressed in all the way so I can put the new pads on?
Old Aug 28, 2004 | 11:53 PM
swannjay's Avatar
rear calipers are funny like that. Its kind of like cracking a safe. You're going to need to sort of "twist" the piston and squeeze the c-clamp at the same time. Also, make sure you loosened the two 17mm(?) bolts with rubber boots (the part that squeezes the caliper when you brake). I know that part just comes off, but, unless you actually loosen the bolts, the caliper won't retract.
you aren't the only one to break a c-clamp trying to figure them out.
Old Aug 31, 2004 | 12:47 PM
Ronin|One's Avatar
I'm doing the same thing i have the front ones on now the rears are giving me trouble.. i don't have the splash shields for the ebake setup.. do I need the whole knuckle to do this conversion? Also using PDM stainless steel brake lines. .
Old Sep 2, 2004 | 08:07 AM
Treyz's Avatar
Wait.. did u put the Z32s on or is it still the stock ones? Basically there's a tool thats sold for the stock ones. It's not really in terms of pushing it back .. it's really twisitng. If you push on them, then u might damage the calipers. You can use pliers to spin it back.
Two-Fortee
Feb 15, 2008 02:22 PM
nismo180sx
Mar 14, 2004 11:29 AM
procastin8or
Aug 16, 2003 10:39 PM
2k2xsexima
Jul 28, 2003 09:00 PM
sr20-s15foo
Jan 30, 2003 08:03 PM
