rear spring slip off... :(
Old Jun 27, 2003 | 09:10 AM
manuelku's Avatar
what should I do if the rear spring slip off the perch? it's some japanese spring and tokico shock.. the rear can't seat very well at the bottom.. is there anything I can do with it?
Old Jun 27, 2003 | 09:27 AM
rudeboy's Avatar
not that i can think of. post a pic....actually......
compress the spring again.
that should let you spin the spring to get it in it's proper location
Old Jun 27, 2003 | 09:30 AM
manuelku's Avatar
it couldn't sit well there.. so it spinned couple coils.. so my car was actually running on shocks for like a day until I found out that it bounced like hell and lowered alot.. I don't have a picture but should the spring end point facing outward or inward??? that should make a different I guess.. it's only the rear tho. the front is just fine
Old Jun 27, 2003 | 10:24 AM
rudeboy's Avatar
there should be a dimple on the bottom spring mount where the start of the first coil shoud sit.
Old Jun 27, 2003 | 07:03 PM
manuelku's Avatar
it just spunned out even I have the starting coil sits on the dimple... btw.. should the dimple facing out or inward?? mine is facing in..
Old Jun 27, 2003 | 11:00 PM
rudeboy's Avatar
i know on the sportlines i use, the printing faces normal..
like the letters are in the normal upright position.
if there is text on yours then that is how they sit.....or suposed to
po_bo
Jan 9, 2010 08:36 AM
asalatt
Mar 23, 2004 06:24 PM
ryan15
Mar 7, 2004 11:18 PM
bonomo
Jan 29, 2004 10:29 AM
positron
Sep 24, 2002 09:46 PM
