suspension
suspension
when im on the high way doing about 50 or anything over my car kinda feels loose. Like the steering is not tight. i was thinkin new tie rod ends cause i figured the bussings were out cause its a 93 240. anybody have any input on this...and whats so much better about aftermarket tie rods?
is it a "floaty" feeling, or more like a shimy? There could be other things causing the feeling... possibles from the top of my head - tension rods, loose lugnuts, bent wheels, bad alignment in the rear (yes, rear), as well as the tie rod end issue mentioned
Sizzzoooo
Mar 11, 2002 01:56 PM
