Suspension Noises
Suspension Noises
I have a 96 SE with a stock suspension set-up (except for a strut bar) and when I go over large bumps/dips etc. I can hear a horrible noise coming from the front suspension. The sound is most audible in the morning particularily when its cold out, or when the car has not been driven in a while. When the tempature goes up the sound can barely be heard. It sounds almost like a rubbing or a creaking noise, has anyone else encountered this same problem or have any insight on what might be the cause?
make sure all your bushings are in proper order... maybe some of them are worn out or broken.
cold weather tends to make things make funny noises. Just give everything a good go through. You probably have worn parts somewhere.
Alteus
May 9, 2007 12:55 PM
DRFT240
Apr 24, 2004 12:17 AM
santana
Oct 15, 2003 05:24 PM
