Tire Size Question...Clueless (Searched)
Old Jun 11, 2006 | 07:29 PM
S13NismoStyle's Avatar
Question Tire Size Question...Clueless (Searched)
Ok, i got 2 quick questions and i hope i dont get flamed.
I have searched a few forums and havent found a definative answer and decided to ask as a last resort.
I got a set of Sportmax 962(i know alot of people dont like them) for very very cheap from a friend($250).
I got 17X7 +38 up front (yeah i know its very weak) and 17X9 +35(equally as weak) but i was going to use at least 15mm spacer with 60mm ARP lug studs up front. I am not terribly worried about flushness, i just want the front wheels to some what match the rear wheel flushness. Will that do it?
As for the second question. What size tires should i run with this setup? I would like to run 225's up front, but think that might be to big. More like 205 or 215's right? And for the rears i was thinking a 245 or so and 40 series tire. Will that look decent(as in neither of the tires look stretched or should i run different sizes?
Any help would be greatly appreciated as i am clueless about this and have been reading like mad. Thanks again for the help.
-Chris
Old Jun 11, 2006 | 11:13 PM
Levi SPL S14's Avatar
215 front 235 rear
Old Jun 12, 2006 | 05:20 PM
jspaeth's Avatar
This helps alot....you actually learn what you are doing better if you calculate the stuff yourself:
http://www.miata.net/garage/tirecalcold.html
Old Jun 12, 2006 | 06:42 PM
THANKs
Cool, thanks alot fellas, i appreciate the input.
Boost_or_bust
Jun 10, 2007 10:41 AM
StarScream_s13
Jan 21, 2006 03:32 PM
chrisramos671
Oct 21, 2005 04:42 PM
SagxaZefiro
Sep 24, 2003 07:30 AM
altima/240sx
Jan 4, 2003 04:54 PM
