snow tire size for 17"
Old Dec 23, 2002 | 12:12 PM
altima/240sx's Avatar
I was wondering what would be a good size match up to put on a S13 for 17" tires front and rear. It will be seeing a few snow and ice days if i put them on, so whatever has the best traction would be appreciated
Old Dec 23, 2002 | 02:41 PM
I'm with Stupid's Avatar
Wouldn't you save a lot more money if you just bought a couple(or 4) stock steel wheels and used them for snow?
Old Dec 23, 2002 | 03:20 PM
right now i'm rolling on stock rims, with M & S tires. But I was just curious. I was gonna get a new set of tires for my other rims, and just in case I decide to switch em, I wanted to know what would be a good size around. Most likely I won't put them on, but I would also like to know the best size around for control and traction even for normal weather.
Old Dec 24, 2002 | 07:19 AM
Justin.b's Avatar
17" snow tires are not a good idea.
Unless your brakes are so large that you can't run a wheels smaller than 17", then go with a set of 15" wheels (steel or used alloy) and have snows mounted on them.
Especially since mounting alone will cost you ~$100 to change from snows to summers if you have them on the same wheels. And the tires are going to be much more expensive in that size as well.
-Justin
Old Dec 28, 2002 | 10:54 AM
SilvaPwr's Avatar
use chains! hahaha
Old Jan 4, 2003 | 05:44 AM
boro240's Avatar
or you could just move to hawaii
Old Jan 4, 2003 | 04:54 PM
I just got back from Hawaii, That place is beautiful. I wouldn't mind living there, but its just so damn expensive. You know what though, i didn't see too many 240's down there. I was in Makena, Maui and Waikiki, Oahu mostly
drifterz73
May 9, 2007 05:57 PM
StarScream_s13
Jan 21, 2006 03:32 PM
thegary
Mar 2, 2005 10:00 PM
ebanfan
Nov 4, 2003 07:32 AM
s240r
Apr 12, 2003 09:35 PM
