very rough ride
Old Apr 20, 2007 | 12:02 AM
lengnoou's Avatar
very rough ride
i recently replaced the rear shock absorbers on my 95 240sx that i want to return to fully stock. i jus had this car for a month and got ripped off on it. i dont know how smooth the 240 really is supposed to be, but i checked all shocks and see that the rear shocks are covered with oil. so i replaced them, since they were dead. im not sure if the fron tstruts are dead, but since i have replaced them, the ride is some what smoother, but still a little bumpy.these shocks are kyb gr-2. could it be that the two front struts are dead to? theres no oil leaks one them. also i have 18X8.5 tires in the front and 18x9.5 in the rear. could it be the big rims/ tires that are making my ride not so smooth? please club240 help a fellow 240 brother out with this so i can get started on modifying this thing
Old Apr 20, 2007 | 12:04 AM
lengnoou's Avatar
correction, i only replaced the rear shocks
Old Apr 20, 2007 | 12:43 AM
re037's Avatar
a thinner tire side wall will sacrifice comfort for handling.
Old Apr 21, 2007 | 09:53 PM
yea those wheels n tires are gona make it rougher, what offsert are your wheels? just save and buy coilovers dont buy that gr2 crap again
Old Apr 27, 2007 | 11:57 AM
NiSmO Knight's Avatar
The thicker the sidewall is, more comfort and not as quiet (pending tred design)
The thinner the sidewall is, better handeling (more feed back) but sacrifice your comfort and depending on tread design again, noise is an issue (like Dunlop)
Old May 22, 2007 | 01:41 PM
ConceptS14's Avatar
he said he wanted to return the car to "fully stock" so the GR2's are a good pick.
but then again. a stock 240 doesnt have 18"wheels.
lengnoou: the roughness comming from the front of the car? then you're probably right about your fronts being weak. if it's pretty even all around the car, it's probably the wheel/tire combo, you running on what 35series tires? ha.
zako
Apr 24, 2007 10:40 AM
jmhayes
Nov 24, 2004 04:02 AM
DRiften
Jul 30, 2004 09:20 PM
boost infested
Sep 6, 2003 08:52 PM
Strizzy
Apr 9, 2003 08:48 PM
