Wheel advice, offset, staggerd or no?
Old Mar 4, 2006 | 10:39 PM
nsn240's Avatar
I've been doing all sorts of reading about offsets, staggering wheels etc... my plan is to run
1) 17x7 +25 fronts w/ 17x8+25/30 rears OR
2) 17x8 all around, +30 front, +25/30 rear
I have read differing opinions on the "staggerd will make you understeer" but i from what i gather, it doesnt make much of a difference. For the offsets, im looking for flush, w/ fender roll if needed, no pull.
car is an s13 hatch, about 200-230hp... just judging w. the *** dyno, and cars raced.
opinions appreciated, pics would be great
Old Mar 5, 2006 | 12:46 AM
Helghast's Avatar
Research..
http://ziptied.com/forum/viewtopic.php?t=2542
70+ Pages to think about.
Old Mar 5, 2006 | 04:07 AM
17x7 +25 is weak as ****, thats almost a inch sunk in, 17x8 +25 should be pretty ok with squared tires and good (functional) amount of negative camber + fender roll, maybe a little sunk, what wheels are u looking at anyways?
Old Mar 5, 2006 | 10:00 AM
nsn240's Avatar
Originally posted by Helghast
Research..
thanks for the link, ill definately be going through that one
yea, 17x7 +25 is really weak, not sure what i was thinking there... i think a 17x7 +15 up front would be more like it. But a 17x7 is pretty ****ing skinny anyways.
I think 17x8 +25 all around would be a nice fit... i could always through in a spacer if i need.. Could i tuck the 17x8 +25 in the front with stretched tires+roll and no camber? (no coilovers or plates, yet)
Wheels, i like the looks and price of the 5zigens, but the offsets for 4 lug suck *ss... only 17x8 +35. Any suggestions on a 17x8 4 lug? I might just go with the zigens +35, and throw in a 5/10mm spacer
isnt ~24.5mm = 1 inch?
Old Mar 5, 2006 | 02:16 PM
Levi SPL S14's Avatar
17x7 need to have negative offset to be flush.
17x8 +0 will be flush with minor fender roll.
Old Mar 5, 2006 | 05:40 PM
8" +25 around if anything
Old Mar 5, 2006 | 08:11 PM
isnt that more for S14
Old Mar 5, 2006 | 08:40 PM
nsn240's Avatar
17x8 +0 requires more than a roll, with no camber... i saw a pic of that in the link above... ill try and find it
Old Mar 6, 2006 | 12:03 AM
Helghast's Avatar
17x8 +0 is good, but if you don't want to pull..you'd have to camber and use 215/40 tires.
Old Mar 6, 2006 | 02:53 AM
17x8 +0 is okay for S13.
I had that on my old car.
That was the weakest i had next to stock.
Old Mar 6, 2006 | 04:51 PM
Fast1One's Avatar
17x9 +15 all around? OOOO...do it!
Old Mar 9, 2006 | 10:20 AM
juujai's Avatar
17x9+15 would result in ~3 degs camber.
i say you figure out how much -camber you want and i'll tell you the size. rather than buy wheels and then adjust camber to accomodate that.
for street 1-2 is fine if you want 2degs you can go like 17x9 +20-22. with 1deg you can go higher like 17x9 +25-30. for autox with -4 you go with something like 17x9+10. beware some coilovers even have trouble clearing 17x9+20 so go measure up.
i'm guessing you don't have 5 lug, hence the wimpy wheel sizes x7 x8... you do realize that going from 25 to 30 offset in the rear will actually sink it 5mm. what's the point? get as low as possible 17x8+20 would be a decent fit not hot but not ugly. every mm added to that well sinks it in that much more. figure it out yourself
17x8+35 would be about 1/2 inch more sunken than 17x8+20 etc. dig through pictures to find your fit. if you must do x7 x8 then get as close to 0 offset as possible
Old Mar 9, 2006 | 01:44 PM
dont be afraid to roll or pull
17x9 +15 fits well with 225/45 imo
Old Mar 10, 2006 | 09:58 PM
nsn240's Avatar
yes, i know how offset works... im still looking at options, not going to buy anything for a while yet. Yes, i realize 15mm is ~1/2inch. my friend actually runs 17x8+35s in the rear and they suck, from what i can tell, another inch (25.4mm) would make it around flush, hence the 17x8+25 i was asking about... +25 will still be sh*tty sunk though. i know how all the sizes and stuff work, and more trying to figure out how the sizes fit
I ruled out the x7 and decided atleast x8 all around and atleast a 17x8 +25 offset... not because 4lug or wimpy sizes, i dont think i need anything much wider (tire) that that,. Maybe a 9 in the rear for future ****, but its not needed for the power i have now.
Again though, i cant adjust camber with a stock suspension. I need coils and rucas first. thanks for your advice on the sizes though, i'd probably run 1 or 2 degrees camber, whatever gives best street wise
silviaks2nr- thanks for the pic, can you get that other one working?
Old Mar 11, 2006 | 07:55 AM
it's being lame for some reason, go to 240sxforums and look in general tech, there is a post your wheel thread and this pic was on the first page. it looks good.
super_240
13
Jan 26, 2004 04:16 PM
AadosX
Dec 16, 2003 05:03 PM
AadosX
Dec 16, 2003 10:34 AM
87camarodan
Oct 29, 2003 08:55 PM
super_240
Aug 28, 2003 10:30 PM
