which z brakes for s14
Old Aug 1, 2004 | 10:49 PM
Ncal's Avatar
which 300zx brakes are the closest to direct bolt on for s14. what modifications will have to be made?
also do the rear calipers say nissan on them like the fronts?
Old Aug 1, 2004 | 11:05 PM
Is there even a difference between how hard each is? I think they are all the same. Search around for Z32 brake conversion for more info.
I'm pretty sure the rears don't say Nissan...rear calipers usually don't have anything on them
Old Aug 2, 2004 | 03:33 PM
S13dude's Avatar
Negative on the rear calipers. Importnut.net/300zxbrakeswap.Every thing you need to know.
Old Aug 5, 2004 | 11:17 AM
JeromeS13's Avatar
Yah, they say NISSAN.
Old Aug 10, 2004 | 12:04 AM
barrigaS14's Avatar
nothing is special about the brakes. it just depends on the width (26mm and 30mm) and the dust shield that needs to be cut to allow the bigger rotors. in the rear you can not use the e-brake unless you get the drum brake setup from the Z32.
Old Sep 1, 2004 | 10:00 PM
Racerboy1320's Avatar
i'm pretty sure about this but corrct me if wrong, 90 is 26mm aluminum calipers, 91 to halfway 92 is 30mm aluminum calipers and from halfway 92 on they are a regular cast caliper, much heavier, i got the 91 spec 30mil aluminums
Two-Fortee
Feb 15, 2008 02:22 PM
2forties
Aug 16, 2006 11:21 PM
S13DET
Aug 30, 2005 04:52 PM
1995 240sx
Jul 30, 2005 01:40 PM
d4vech3n
Jan 5, 2005 08:19 PM
