blown turbo question
Old Nov 16, 2004 | 06:46 PM
BMadd's Avatar
OK, I think my turbo is going, going, gone. I have a RB25det, and it is only boosting at 5 psi(+/- 1/2psi) and I have a light coating of oil in my intake pipes and recirc pipe from bov. could this be the compressor wheel? anything else to check? everything is completely stock.
Old Nov 18, 2004 | 06:45 AM
srslider's Avatar
Does it make any unusual noise? Check the shaft play on the turbo, Does it move? How much? If it's unreasonable I would consider removing the turbo and having some one else inspect it and either have it rebuilt or upgrade it. The problem with you only boosting at 5#s The wastegate sounds like it is opening prematurely, Do a little investigating and see if something is wrong with you wastegate or if you have any other obvious problems. The oil is normal, as long as its not excessive. It's blowby vaporized oil in the crankcase is recired into the intake pipe on the turbo. Write back I'd like to know what has happened. good luck
Old Nov 20, 2004 | 04:13 PM
jbask's Avatar
if you wipe your finger inside the intake pipe you shouldn't have wet oil on your finger, if you do have wet oil after you wipe, your turbo is probly on its way out.
Old Nov 21, 2004 | 09:22 PM
driftjunke's Avatar
Time to upgrade, t3/t4 .63 ar, 50 trim works great.
J.D.
Old Nov 22, 2004 | 02:25 PM
Sic95gst's Avatar
Do you have a crankcase breather? If not then you may be getting oil from the crankcase. It's a commen problem on most turbo's. That's why they install carnkcase breathers. My DSM does it. A cheap alternative is to buy a inline see threw fuel filter and put it in between the crankcase ventalation and where it connects to the intake. This way you can see oil build up and dump it out if need be.
Old Nov 29, 2004 | 12:06 PM
TWAN's Avatar
or just get you a catch can. a good upgrade for the turbo as well as the motor.
Old Sep 7, 2006 | 11:02 AM
nisilvia's Avatar
turbo
is the stock turbo a t3?
Old Sep 7, 2006 | 03:17 PM
forcefed240sx's Avatar
Re: turbo
t2 flange on a t28 turbo the wheel is a t3
the t25 on the s13 is also a t2 flange.
godfather2112
Jul 1, 2006 02:26 PM
Sleepy240
Sep 15, 2005 04:59 PM
Sleepy240
Aug 13, 2005 10:49 AM
s14Drifter
Oct 18, 2004 02:42 AM
s240r
Jun 9, 2004 10:38 PM
