found 1 diamond in the ruff need help polishing
Old May 6, 2005 | 09:09 PM
FlickIT240's Avatar
Talking found 1 diamond in the ruff need help polishing
ok so i bought a car from a friend and had a ka24e and he blew it and so he put in a DE and couldnt get it to run and sold it to me for 600 bucks with the eibach lowering springs and the injen intake. So i went to a junk yard and got a MAF off a 2.4 stanza and i got it runnin but really Ruff and tends to shut off when i come off the throttle to fast . So anywayThen i Got a Garrett M24 off my friends blown 300zx for 50bucks I think im mechanicaly inclined enough to do the turbo install if I only had some good directions to follow and maybe a list of parts I will need I dont want to leave the internals stock but Im only trying to run like 10lbs so if anyone has some info that they think will help send it this way.
so far I know i need an exaust manf. and intercooler kit but what else like for fuel management but im not sure . Ive got about 2gS left in the "fast car fund" so tell me what you think Thanks in Advance I look forward to posting the results of any advice i get from this forum Thanks again....FLiCK iT HARD FLiCK iT OFTEN
Old May 6, 2005 | 10:33 PM
LTSCUDRFT's Avatar
1: make it run properly.
2:check the compression make sure it's really good like around 180 and up. New is 200-210psi
3:as for fuel mods a set of SR injectors for safty reasons & an aftermarket FPR with a FMU would be good OR
what i would do is go to http://www.precisionracingonline.com/megasquirt.html
and order that and get it programmed for your car, it's cheap, it works and it's a stand alone engine managment, what more can you ask for. that is all i can think of at this moment, other people should have more to say
(FPR= fuel pressure regulator. FMU= fuel managment unit)
EDIT: the megasquirt over the FMU, you'll still need the AFPR.
Old May 6, 2005 | 10:36 PM
FlickIT240's Avatar
Thanks for the link i had trouble finding an FMU Ive been talking with a friend of mine thats a mechanic out here and he told me that i could use that to solve alot of the ruff running problems
Old May 6, 2005 | 10:45 PM
FlickIT240's Avatar
If i am turboing the KA24DE do i need a new maf because i would also apreciate any links someone might have to one of thoes
Old May 7, 2005 | 03:02 AM
nerd22's Avatar
ummm.. how much horsepower are you trying to produce with your ka-t? if you want to run a safe setup without internals and with stock fuel management i wouldn't boost over 6psi.. there's really no need to get a new maf unless you change your injectors.. if you change your injectors, you'll need to change your fuel pump & possibly a larger maf (z32 preferably) i'm not 100% sure if this is all true.. i've been reading up on this as well.. all the information is coming out of my head randomly.. somewhat in order? but there's really no need for upgrades unless you're trying to go big with the horsepower.. check out the website phatka-t.com they have parts for sale there and they also have a somewhat useful forum! ..and i think this post is quite long enough.. and if any of the information i've given you seems off or wrong, by all means, please correct me!
Old May 7, 2005 | 06:46 AM
FlickIT240's Avatar
ok well that didnt help much i know i need some new internals but im asking what would be some good combinations im having trouble on where to start too. I dont know where to get a z32 Maf how much do they run .
Old May 7, 2005 | 10:59 AM
FlickIT240's Avatar
ok so the z32 maf will definatly work on my 3 prong wiring harness? because it looks like a six prong to me (at least in the ebay pics it does)
Old May 7, 2005 | 11:09 AM
FlickIT240's Avatar
Up for auction is a used mass air sensor from a '92 Nissan Maxima. Nissan part # is 22680-16V00. Externally this is the same as the Z32 but it flows a little less. It still has the 80mm connection and even the same bolt pattern. In fact, the plugs are the same too. This is a HW-4 maf for anyone using a S-AFC. The wiring for your SR/KA/CA is the same as the Z32 as well. Unless you are making 300+whp, this maf will work fine for you. Perfect for those setups using an S14 or S15 T28 turbo. will this MAf work i really only want to push 300hp/ 300ftlbs The wireing harness on the car is 3 prong
HYPROPULSION_R
For Sale - Wheels / Tires
Oct 11, 2007 01:56 AM
battosaii930
Aug 4, 2007 05:19 PM
jramosthe1st!
Feb 7, 2007 10:10 PM
adarrell
Feb 23, 2003 08:04 PM
Ryan
May 9, 2002 12:52 PM
