Greddy Turbo kit for 96-98 240sx
From my understanding the kit will bolt up to a 95 but the reason its for the 96up is because of the fact that it is OBDII compliant. heres what you gotta do:
-buy the greddy turbo kit and intercooler
-have your ecu tuned by JWT
-sell the greddy ecu that they give you
-boost till you blow your motor
-rebuild motor
-boost higher
thats it, in a nutshell
-rebuild motor
-boost higher
Its not that expensive either. You can get it from www.jspec.com for the kit and intercooler $3500 SHIPPED, or on ebay for Buy It Now with intercooler for $3100, plus shipping. The prices will come down in a few months, Greddy needs to make back their initial investment. Once they do that, their prices will lower. Patience is a virtue.
ya, go pick up the new Turbo magazine. They have a good write up, pictures on the kit w/IC installed, and a nice dyno chart with the stock power, kit power, and kit w/IC power. You should still go pick up the magazine, but here are the numbers anyways.
STOCK - 140hp 151tq
Kit @ 5.7psi - 194.6hp 194.9tq
kit w/IC @ 7.8psi - 219.5hp 250.6tq3
hope that helps~!
STOCK - 140hp 151tq
hope that helps~!
I talked yesterday to owner of the local speed shop (they are a Greddy authorized dealer), and he told me the reason it wont work on a 95 is the e-manage is not compatible with the obdI computer. I might go ahead and buy the kit and see if I can swap in an obdII ecu from a 96 (it works on hondas). If anybody knows if this is possible please let me know.
My other option is a custom kit with a k26 turbo and a lot of irritation.
maybe instead of trying to wire in a obdII like all the honda guys do. Maybe you would be better off selling the Greddy Emanage, and getting a JWT ECU. Its easy to find harnesses for Honda's cause everyone and their mom has one. You would have to pya a hefty price tag to get your system to run a obdII comp. w/o throwing codes. This is what I was going to do if I got a '95...but I found a '96 so its all good~!
I guess another option would be to buy another e-manage that is not preprogrammed and take it to a tuning shop with a dyno. I really like like the idea of being able to reprogram the system. My eventual goal of 450 hp will require much larger injectors and engine work. A stand alone unit would work but they are expensive as hell and a jwt is not reprogrammable without sending it off to be reworked.
Thats true. Maybe you could work out some kinda trade type deal with a shop or something. See if they will let you swap out eManages and pay cheap for some dyno/tuning time. Anyways, I hope all works out well for ya. Definitly keep us posted on what you do and how you like it. Thanks~!
I'm probably going to use my apexi safc for fuel programming and an aem uego wideband o2 meter to help tune everything. I'll make sure to do a write up with pictures on how it all works out. I'll gonna ty to do all this some time in may or june (depending on funds at the time).
WhoDiddy
Feb 2, 2006 07:45 PM
yektik99
Nov 14, 2004 10:42 PM
nissmo240sx
Dec 10, 2002 08:31 PM
