Idle problem?
Old Aug 19, 2003 | 12:07 PM
505SilEighty's Avatar
Idle problem?
After i finished putting in my turbo kit that took me too long to make i have a problem with it idling. When i first start it up it will idle fine when i rev it and let it go back to idling it will die. I check the ecu code and it gave me a MASS air flow sensor code but what is weird is that all the vac lines are hooked up like it should be but it still dies. Any idea?
Old Aug 19, 2003 | 02:05 PM
rudeboy's Avatar
mabey there is a small leak somewhere
i know you said everything is plugged but sometimes we can hear or see these things
you need to go and tripple check ecerything.
and try a diffrent maf sensor just to check that again
Old Aug 19, 2003 | 06:09 PM
Alright it stopped dying on me by itself. but i think that the ecu had to get used to a different vac on the turbo. Thanks tho
uvamosk
Aug 12, 2005 07:31 PM
japporeyser
Apr 7, 2004 08:15 PM
4k49d3kjf3
Aug 20, 2003 03:26 PM
altima/240sx
Sep 28, 2002 08:04 AM
