Post Your Turbo Setup !
Old Jan 11, 2003 | 11:38 PM
ca18det's Avatar
in in the great midwest plains of good ole usa.
Old Feb 2, 2003 | 05:36 PM
lbcklik1486's Avatar
CA18DET, 720 injectors, wow, is it realiable enuff to have fun every weekend? Also, whut kinda mileage do u get.. dumb question i know. just curious. Badass car setup though man.
Old Feb 3, 2003 | 07:55 PM
cdigity's Avatar
setup:
kkk k27
jgs front mount
jgs custom manifold
hks blow-off
audi wastegate
vortec f.m.u.
walbro 255lph
split-second a.i.c. w/ 2 add. injectors
stock ecu
act 6-puck
apex-i n1 dual
turbonetics boost controller
Attached Thumbnails Post Your Turbo Setup !-turbo-install-pics-022-medium-.jpg
Old Feb 4, 2003 | 12:36 AM
Monkey Force's Avatar
outstanding setups fellas
what is a fmu? fuel management unit???
The only problem i had with CA's is the ****in water lines kept breaking. It was always a coolant issue but easily fixed with stainless lines
Old Feb 5, 2003 | 08:28 PM
SoloDrift1's Avatar
Yup. fmu manages ur fuel. its boost sensitive or vacum sensitive. either way u look at it. it sends more fuel to match ur boost.
Old Feb 11, 2003 | 06:54 PM
im about to change my setup to:
T04S ar.70 60-1 T4 exhaust ar. 1.06
HKS racing wastegate
ON A 13B!!!!!!!!!!
EDIT: Disregard I cannot do this anymore so its still the T04E for now ..............
Old Mar 9, 2003 | 03:54 PM
dragonm's Avatar
1993 240sx with sr20det
custom polished fmic
centerforce stage 3 clutch
walbro 255lph secondary fuel pump
blitz sbc boost controller
cartech fpr
1/4mile ???
last year
ka24det
t03/04hybrid garett turbo
walbro fuel pump
cartech fpr
13psi controlled by turboxs mbc
clutchmasters stage 2 clutch
arias low compression pistons
than i blew it up tuning for a streetcar shootout.so sr swap it was!!
1/4 mile 12.8 @112mph
Old Mar 9, 2003 | 07:17 PM
RUTH'LESSDET's Avatar
-S13 blk top
-HKS FMIC
-HKS 2530 w/extension pipe
-Z32 maf
-555cc tomei injectors
-reprogrammed ecu @4bar fuel pressure boost cut removed, fuel cut removed etc
-Walboro fuel pump
-3"downpipe
-APEX DUaL n1's
-ACT 6 Puck and HD PP
-I sold my boost controller...blitz sbc and power id damn why did i do that!!??!?!!!...im on stock boost 8-10 psi on hks turbo to my understanding
-Can any body estimate how my car would do in a 1/4 mile with this setup my motor is being rebuilt right now as we speak, and i dont know what to expect in the power department or time department. I blew some rings and im getting everyting fixed
Old Mar 9, 2003 | 09:21 PM
rps13 sr's Avatar
Originally posted by RUTH'LESSDET
-S13 blk top
-HKS FMIC
-Z32 maf
-Walboro fuel pump
-3"downpipe
-APEX DUaL n1's
where are u getting it rebuilt
Old Mar 19, 2003 | 01:56 AM
13's is my guess
Old Mar 19, 2003 | 08:47 AM
  #26
2-FORTY_TERROR's Avatar
Talking FOR NOW!!!!!!!!!
S13 SR20deT Red Top
RX6B TCW77LS Apex'i Turbo
550 Injectors
Greddy V-Spec Intercooler
custom 3" DownPipe
HKS Super Sequential BlowOff
I really im considering doing a RB25 swap, its hella lot stronger and has so much more potential then the SR.......
TERROR
Old Mar 20, 2003 | 06:13 PM
  #27
kade4me's Avatar
Custom Equal Length Tubular Manifold & Downpipe with Flex Adaptor
Custom Stainless Steel Test Pipe
Garrett T3 Turbocharger with Wastgate & Factory Dump Valve
Conquest Front Mount Intercooler
High Flow K&N Style Intake
Custom Center Feed Fuel Rail with Twin Outlet
Sard Fuel Pressure Regulator
300zx-TT Fuel Filter
Walbro 255 lbs/hr Fuel Pump (300zx-TT Style)
Jim Wolf Technology 370cc Turbo ECU, without Top Speed Limiter & 7,000rmp rev Limiter
Nismo 370cc SR Injectors
JSPEC HKS Super BOV
HKS Type-O turbo timer
Nismo Clutch
Nismo Lightweight flywheel
assorted gauges
B&M short shifter..
LSD is on the way..oh, ive got a host of suspension/exterior mods too. Blitz NUR-spec is comming. I'm only running 7lbs of boost, but the engine rebuild and EVC IV is comming Any guesses of 1/4 et's?
Old Mar 20, 2003 | 07:37 PM
  #28
Justin.b's Avatar
Originally posted by cdigity
setup:
kkk k27
jgs front mount
jgs custom manifold
hks blow-off
audi wastegate
vortec f.m.u.
walbro 255lph
stock ecu
act 6-puck
apex-i n1 dual
OK, I checked out the pic and have a question - What are you using for ignition? The list doesn't seem to include a coil pack ecu setup, but the wires don't go to the distributor. Are they just disconnected in this picture?
In any case, nice setup!
-Justin
Old Mar 21, 2003 | 07:07 AM
  #29
spitz7985's Avatar
where'd you get your manifold?
Old Mar 21, 2003 | 12:42 PM
  #30
kade4me's Avatar
Custom Fabricated..I might be able to get you one if you send some cash..are you interested?
