rebuilt sr redtop startup help!
Old Aug 28, 2006 | 12:28 PM
2fast4y0u's Avatar
Question rebuilt sr redtop startup help!
ok, i just got the whole motor rebuilt. everything but a new crank
im having the same problem as before the rebuild.
IF i can get it started i have to hold the gas down and crank for like 15 seconds before it fires. once it does start i have to move the CAS around to get it to idle by its self. once that happens it will idle high then low and chug like crazy. 800 - 1200 rpms and then fall on its face and die. Then i have to start all over. i checked the MAF by unplugging it while it was running and it does the same thing. if i can get it started i pull the plugs and they are super fouled out and dripping with gas. clean them re-install and it wil run for a min or two then shut off. checked all coils and all are good. but there is a wire that is connected to all of the E connector on all 4 coils that is an " engine ground " that bastard shocked the **** out of me!!!
any info....please help.
i started it this morning and it ran for about 30 seconds and died. havent tried it sense
Thanks,
Jay
Old Aug 28, 2006 | 03:19 PM
if you unplug it and it does the same thing as before then it may be bad, do you have a friends or try n get a different one..
Old Aug 28, 2006 | 06:31 PM
2fast4y0u's Avatar
no body within 50 miles of me has a 240... not to mention an sr
Old Sep 22, 2006 | 06:22 PM
silentvoice19's Avatar
lol somethin funny about that my buddy has the same problem on his GSX im not kidding crazy idle smells horrible of gas. We replaced the spark plugs checked the timing order made sure it was right.That was pretty much it the basic crap.
icon1
Oct 24, 2005 11:59 PM
Skiboard06
Apr 8, 2005 08:21 PM
Skiboard06
Feb 5, 2005 07:46 PM
Skiboard06
Jan 11, 2005 03:15 PM
beefcake6681
Jun 30, 2003 03:39 PM
