Running to RICH!!! help me!
Old Jan 29, 2006 | 01:46 PM
bxdiamante's Avatar
Angry Running to RICH!!! help me!
to let eveyone know from my previous posts, I took my car to wings and they got it running so here are the problems now. Ok, Its still rich, the spark plugs i put in on saturday, and drove it for a little, and its coated in black. I put the maf, nothing, still black smoke coming out. I woke up in the morning and it didnt start at all, just cranking, so I took a clamp and choked the fuel line coming out of the fuel filter, then it kicked, and finally ran. Even though I choked the fuel line its still running rich, I removed the intake, thinking it was rich because the kink in the piping, but it was wayyy open and it was still running rich. So even if I put the stock sr intake it still wont make a difference. Also the car runs on 3 cylinders, if i play with the coil wiring for the first one, it gets normal, so its maybe a loose connection or its the coil itself. I was also thinking that the richness could be caused by, a 02 sensor, coolant temp sensor, fuel pressure regulator and the maf. Is there any other things? How can I check these, Whats the voltage on the Maf supposed to be 1v? which wires do I check?
p.s: it runs rich when the car is running normal to. Not only on 3 cyls.
besttecca
Oct 8, 2006 11:21 AM
KeN VeRsUs RyU
Nov 28, 2005 07:46 PM
war
Apr 24, 2005 03:26 PM
nishioSX
Jan 26, 2004 10:41 PM
pezdespencer
Jan 22, 2004 12:22 AM
