safc2 management?
Old Oct 10, 2005 | 06:45 PM
1993240sx's Avatar
safc2 management?
I am turboing my ka and wanted to know if i can just buy a safc2 instead of a greddy e-manage or do i need the e-manage instead?
Old Oct 10, 2005 | 06:50 PM
nsn240's Avatar
yea, you can use the safc to tune for the larger injectors... imo it would be best to have your ecu tuned and run the safc for minor tuning
Old Oct 10, 2005 | 06:54 PM
1993240sx's Avatar
iight, im not planning on gettin injectors right away but I am going to get them. do you think 370cc and a 255lph fuel pump would be sufficent for a Garrett t3/t043 60 trim .63 a/r turbo? and do you think ill be alright running for a while on stock fuel system?
Old Oct 11, 2005 | 03:03 PM
nsn240's Avatar
woah... if you are gonna run ANY turbo, you MUST upgrade injectors... it's not an option. with out them, your engine willl run lean and burn up
Old Oct 11, 2005 | 03:17 PM
1993240sx's Avatar
iight man thanks, you are a huge help
Old Oct 12, 2005 | 09:59 AM
Kaion1000's Avatar
You can temporarily run an FMU with a Walboro 255lph fuel pump, until you get injectors and an SAFC. Do Not Run a turbo setup without upgrading your fuel setup, thats a very cool way to loose a motor.
Old Oct 12, 2005 | 12:27 PM
nsn240's Avatar
np man, let me/ us know whast setup you decide to use and it'll be easier to help w/ injector sizes and crap
Old Oct 12, 2005 | 09:25 PM
yiaracer's Avatar
you can run stock injectors......i think that the stock ones are 260cc....correct me if i'm wrong....but a tuning shop near where i am at said 270cc injectors should be able to handle 6psi.....i have a ka with a custom turbo on it and stock injectors...i an using the emanage ultimate to control the fuel and it runs just fine...doesn't lean out on me...also an using a fmu though....
Old Oct 13, 2005 | 04:20 PM
nsn240's Avatar
i dunno... stock t25's boost is 7psi so that wouldnt help... to make more power and stay safe. I'd upgrade injectors
Old Oct 26, 2005 | 09:11 AM
1993240sx's Avatar
I decided to go with a garrett t3/t04e im building my whole kit for about 2100 w fuel and management included......
Old Oct 26, 2005 | 09:44 AM
Kaion1000's Avatar
sounds good man what's your full setup
Old Oct 27, 2005 | 01:21 PM
socals13guy's Avatar
i would go with a 550cc Injectors for a t3 turbo set up
Old Oct 28, 2005 | 10:02 PM
yiaracer's Avatar
my setup...i have a custom manifold, downpipe, intercooler piping(2.5 inches all the way), first gen turbo and blow off valve, stage 3, 6 puck clutch. just got the emanage ultimate in not to long ago....boosting at 9 psi...
backlife
Mar 22, 2004 06:30 PM
backlife
Mar 14, 2004 04:51 PM
fasterthanthem
Feb 7, 2004 09:15 PM
bnaley
Sep 30, 2003 07:46 AM
Koua Jones
Sep 26, 2002 04:18 PM
