stock BOV's?
Old Mar 12, 2004 | 05:30 PM
tegg_gsr's Avatar
Arrow stock BOV's?
Do you have to recirculate them?
Old Mar 13, 2004 | 05:33 PM
Romeyo07's Avatar
typically a turbocharged car with a maf recirculates the air. so if you dump to the atmosphere you run rich between shifts because the air is already measured.
Old Mar 13, 2004 | 11:37 PM
tegg_gsr's Avatar
so when you get an aftermarket BOV you have to do something with the MAFS
Old Mar 14, 2004 | 05:34 PM
Romeyo07's Avatar
nope. a lot of aftermarket bov's have a recirc. kit
Old Mar 15, 2004 | 06:16 AM
SlydeSHO's Avatar
Yes, you will need to recirculate a stock SR20 BOV because it typically leaks under boost pressure; hence; having your car bog out on you at about 4000 RPM. As for most aftermarket BOV's it is not necessary to recirculate it but it would be best.
Old Mar 15, 2004 | 09:45 AM
Romeyo07's Avatar
cheapest way to go, get 1g dsm crushed bov. Should hold up to aboot 18 lbs of boost.
Old Mar 15, 2004 | 02:38 PM
SlydeSHO's Avatar
Yeap! You can do it that way; however, I don't think it's that big of a deal recirculating the BOV. The recirculating type was only made for Emission purposes, it's not out there to destroy your engine.
Old Mar 15, 2004 | 06:08 PM
Romeyo07's Avatar
Old Mar 15, 2004 | 06:18 PM
SlydeSHO's Avatar
I don't seem to notice any major richness between shiftings having my GReddy BOV recirculate; besides, you would rather have you car running rich anyway because running lean in anyway can cause your motor to blow.
Old Mar 16, 2004 | 05:13 AM
Romeyo07's Avatar
If you DO NOT recirc. you run rich between shifts
DIrtYChErRyS13
Oct 3, 2005 07:07 PM
OBEEWON
Aug 19, 2005 11:28 PM
DIrtYChErRyS13
Aug 7, 2005 11:11 AM
WhiteWolf
Jul 7, 2005 08:38 AM
