turbo oil cooler
Old Dec 7, 2003 | 11:49 AM
87camarodan's Avatar
turbo oil cooler
So i started thinking about what parts im gonna need, and what work i need to do to my car now that i have a junkyard turbo... and I was considering the oil lines,
would it be easier/beneficial, to get an oil cooler off ebay, and run the oil to the turbo, and then through an oil cooler, or maybe the other way... or both? and then back to the oil filter? so it would be like running a normal oil cooler, but in the middle of those lines would be the turbo...
thoughts, oppinions, praises of my genius are now acceptable below this post,,, thanks
Old Jul 18, 2004 | 07:55 PM
bottombunk's Avatar
just run an oil cooler off the filter opening using an adapter. if you run one in betweeen the turbo you will have to locate it more than likely lower than the turbo. if thats the case you might have pressure issues going up to the turbo. im not sure though.
bleachcola
Nov 29, 2006 01:12 PM
drift80
Apr 8, 2004 08:18 PM
kade4me
May 27, 2003 08:10 PM
RNN14
May 9, 2002 04:30 AM
