What turbo for my 1998 s14 sr20det?
Sup guys, just had a question. My motor is bone stock, I want to upgrade the turbo, something much bigger than stock . Im leaning towards the t04e or the Garrett "Big Kahuna".I would like to see around 290 to 360 wheel hp. For the upgrade, will I be fine if I just purchase the turbo and get bigger injectors with a new fuel pump ? I know I will need tuning, but are there any other majors things that I need to know of ?
I think the best help for you is to search the forum a little more. you also did not ask any questions. if you get a bigger turbo all you need to more fuel assuming you want to boost more. so bigger injectors and a fuel pump is correct. then tuning. there are not any more big things you need to know. but millions of little ones. here are some items you may want to search about and read for more info. The maf upgrades and power limits, options for ecu or piggyback tuning, jwt cams, what injectors will fit in the existing rail, other injector options, clutch upgrades, intercooler upgrade, how to make or buy piping, bov, wastegate, what manifold to use with a t04e. another turbo option the GT28.
Honestly I think the t04 is bigger then what you need. The gt28 i think would be better. If im right it fits up on the stock manifold. Boost controller, BOV, wastegate, larger radiator/intercooler maybe!
And just go slowly upwards until you think the engine can't take anymore or change something else and keep on. Good luck.
11Past9
Mar 17, 2010 06:12 AM
574-240sx
Jun 20, 2008 10:48 PM
slipperysilvia
For Sale - Part Outs
Feb 18, 2007 08:58 PM
