Hardline.....to......Slave
Old May 31, 2006 | 06:24 PM
xpcgamer's Avatar
OK I have been collecting all the parts for my 5 speed swap into my s14. Besides getting the flywheel resurfaced new clutch and disc,throw out bearing and all else the last thing I need to find/order is the hardline. My question is this...The hardline drops down from the firewall into a adapter which also has a loop of hardline aswell. How can I or "Can I" connect the hardline directly to the slave cylinder on the tranny? I will have to order the hardline new from the dealer tomorrow so I would like to know what else I need to order. Thanks
Old May 31, 2006 | 08:01 PM
re037's Avatar
just bend it. slowly. careful not to pinch the line
Old May 31, 2006 | 08:15 PM
xpcgamer's Avatar
So it will connect to the rubber line or to the slave cylinder? Should I heat it slightly before I bend it? I am buying it new(the hard line) so I no wanna break it ya know;-)
Old Jun 1, 2006 | 01:03 AM
It will bypass the clutch damper system since it is not needed. It will go hardline, soft line, and then slave. You can bend it without heating just be very careful as not to kink it, or buy a small tubing bender and use that.
cticknor666
Sep 25, 2004 09:08 AM
spoolin240
Apr 16, 2004 06:14 AM
drifterswanted
Dec 3, 2003 03:12 PM
Supranatural
Nov 20, 2003 12:09 PM
duckman240sx
May 13, 2003 05:27 PM
