please help Rpm issues
Old May 30, 2009 | 07:03 PM
Jay_240sx's Avatar
Hey i just did a 5 speed swap on my 240sx and it runs great except that when im in 3rd gear around 5200 rpms the rpms just drop so i have to put it in nuetral and then put it back in gear it does the same in 4th around 4500rpms and in 5th at 3800 rpms does anybody know what it can be please any help is aprreciated i never put a tranny harness in it so i dont know how fast im going and i beleive its still a automatic ecu but im not sure cause it was also having shifting problems when i had the automatic transmission it just wouldnt go into overdrive..
Old May 30, 2009 | 09:25 PM
your best bet is to check for codes and get back to us with the results. but if you want i can take a stab at it with the few details and background information you've provided. i'm thinking your timing is off or you're tps is faulty, it's just a guess though so i could be wrong.
Old May 30, 2009 | 10:38 PM
It sounds like it could be the tps. did you replace it with a manual sensor? I would recommend getting a manual ecu as well.
1991se240sx
Feb 20, 2011 01:09 PM
240smoke
Jul 30, 2008 04:12 AM
jt1583
Sep 17, 2005 09:32 AM
3825
Jan 4, 2005 03:17 PM
EvoMperor
May 27, 2003 10:30 PM
