Slave cylinder
Old Oct 30, 2006 | 04:32 PM
Michael22's Avatar
Question Slave cylinder
OK, so after installing a stage 2 clutch and starting my car again, after shifthing into first, the slave cylinder bursts. Im not sure if this has anthing to do with the throwout bearing problems im having, but now, the car wont start. Anybody have any idea whats up with my car?
Old Oct 30, 2006 | 10:29 PM
what do u mean it bursts? like it blew up or what?
Old Oct 30, 2006 | 10:42 PM
re037's Avatar
not even in neutral?
Old Oct 31, 2006 | 06:31 AM
Did you bleed the clutch?
Old Oct 31, 2006 | 09:50 AM
Michael22's Avatar
Several times i bled the clutch, but the end result was the same, trying to drive the car 3 ft forward, it popped out and all the clutch pressure was gone, because the fluid spilled out all the time.
Old Oct 31, 2006 | 12:08 PM
just replace it then its only like $30 and you may also want to remove the clutch damper box if you have not done so already
jt1583
Oct 20, 2005 06:27 PM
yektik99
Mar 28, 2005 09:19 AM
cticknor666
Sep 25, 2004 09:08 AM
spoolin240
Apr 16, 2004 06:14 AM
Supranatural
Nov 20, 2003 12:09 PM
