AC problem
Old Apr 1, 2004 | 03:18 PM
BlueByU's Avatar
AC problem
doing a swap for sr20det blacktop s14 into a 95 240sx and the shop doing it called and said that there is problem with fitting the ac into the car what could this be.
Old Apr 1, 2004 | 03:27 PM
Moved to Engine swaps, post in the right area
There shouldnt be a problem with the fitment...but possibly the wiring.
Old Apr 1, 2004 | 03:46 PM
bishoptaner's Avatar
ya they are probably pulling your leg the shop i used to work for srewed all most everyone that walked into the shop they probably crossed threaded it and want you to pay for it dont take their carp
BlueByU's Avatar
what doesnt match in the wiring,and what do i do to fix this?
Old Apr 1, 2004 | 03:59 PM
The S14 JDM wiring doesnt match up to the US S14 wiring, so they need to splice it together. I dont know what wires need to be spliced to what wires, but good luck
Old Apr 1, 2004 | 04:37 PM
BlueByU's Avatar
ok they said they had to use the compressor of the s14 blacktop because the bracket,but this causes the lines not to match up.now what.
Old Apr 5, 2004 | 03:41 PM
BlueByU's Avatar
no one has ant ideas?
Old Apr 10, 2004 | 08:31 AM
RBpwrd240SX's Avatar
We just did an sr20det swap into a 95 240 and the stock US compressor bolted right on to the sr20det with all 4 bolts. The only problem was the belt didn't quite line up but we used a K4-345 and cut one rib off and used the three groves that lined up. The belt has stayed on and it turns the compressor. You should not have to use the sr20det compressor.
vortxxe
Apr 29, 2006 05:22 AM
uvamosk
Aug 12, 2005 07:31 PM
altima/240sx
Sep 28, 2002 08:04 AM
kackarot
Feb 11, 2002 07:31 PM
240sxer
Feb 11, 2002 02:55 PM
