Boost and Oil Pressure Gauge
Old Sep 18, 2005 | 08:07 PM
b0rdin4life's Avatar
I installed an Autometer boost gauge in my S14 with a S13 redtop in it along with a Greddy ProfecB Spec 2 boost controller and the two of them read out different boost pressures. The only thing I can think of is maybe I have the boost gauge hooked to the wrong hose? I have it spliced in with a T-fitting off the BOV, is this correct? If not, where should it go? Also, I just bought an Autometer oil pressure guage (not the electronic one), and I was wondering where I tap into to hook it up. Thanks a lot.
Old Sep 24, 2005 | 01:06 PM
Skiboard06's Avatar
i had my boost guage hooked to a T fitting the went on the vaccum line from the throtle body to the fuel pressure regulator never had an issue maybe give that a try
Old Sep 24, 2005 | 01:10 PM
Nismo241's Avatar
Any vacuum source on the intake manifold will work for the boost gauge. For oil pressure, take off the stock oil pressure sending unit, which is right next to the oil filter, and replace it with the fittings that came with the gauge.
Jovan
Mar 29, 2006 09:14 PM
b0rdin4life
Feb 14, 2006 10:53 PM
D Grade
Nov 29, 2005 10:00 AM
240SILV
Jul 19, 2005 03:29 PM
240sxSleeper
May 24, 2005 12:30 PM
