guage clusters:probably a stupid Q
Old Aug 3, 2003 | 10:41 PM
raiden571's Avatar
well, this question is probably borderline retarded. but when you swap in a sr20 into ur 240sx, dont u have to change the guage cluster to give u an accurate reading, because the ecu would have been made for that engine but the gauge cluster is for a different car. i have just confused myself even worse and i hope someone understands my question and can answer it
Old Aug 4, 2003 | 12:38 PM
DC2R Munky's Avatar
I am pretty sure 89-90 models you have to swap the gauge cluster to a 180sx / Silvia because the 240sx speedo isn't compatible. 91 and up should be fine though.
Old Aug 4, 2003 | 12:56 PM
raiden571's Avatar
wont the 180sx's gauges read in kilometers and not miles. I can put the engine, but that doesnt make me a genius, i cant calculate metric to american while going down the highway
Old Aug 4, 2003 | 07:02 PM
I'm with Stupid's Avatar
Speed sensor on the SR tranny needs to be swapped with the KA so your mph speedo will be correct. The tach needs to be swapped in SOHC clusters because SR's and DOHC KA's use a different voltage. Though I'd rather have the SR tach for the higher redline anyway.
Old Aug 5, 2003 | 07:30 AM
raiden571's Avatar
what if i just kept the old guage cluster in the car, would i have an accurate reading
Old Aug 5, 2003 | 08:58 AM
DC2R Munky's Avatar
You should if the speed sensor sends the same signal. I don't know whether it does or not though...I'm with Stupid...any idea?
Old Aug 5, 2003 | 11:37 AM
Yes, if you have a DOHC 240 and swap the trannys speed sensor everything will work fine. If you have a SOHC 240, in addition to the sensor swap, you need either a DOHC or SR tach to have a working tach.
Old Aug 5, 2003 | 01:15 PM
DC2R Munky's Avatar
Sweet! Ah...the advantages of not having a pignose!
Nickmerrone
Sep 15, 2009 09:37 AM
sw20fj40
Dec 23, 2005 07:37 AM
itsA240sx
Sep 24, 2004 05:28 PM
Amolao
Jun 22, 2004 07:02 PM
Dres240
Jun 10, 2004 10:20 AM
