ka24e to ka24de???
Old Jul 30, 2003 | 01:17 AM
re037's Avatar
ka24e to ka24de???
anybody ever swapped a 98 ka24de stick into a 89 auto chassis?
if so what were the complications and how much work was it?
Old Jul 30, 2003 | 01:32 AM
SHIFT_Lock's Avatar
2 options here.
#1 if you do put a s14 ka in you can rewire the engine harness to work but everyone i've seen do this seems to have a ghost in the machine.IE the motor acts weird alot idle weird dies for no reason and so on. i have known a couple people do this and get really frustrated and ended up doing option#2
#2 if yo use a 95-98 ka you will need the folowing to make this a bolt in afair.
parts from a s13 ka:
distributor and the coil that goes with it,intake manifold,exhaust manifold,harness ,ecu,downpipe,egr and btu set up, basicly everything except the head and block. tranny will work. also you will need the s13 DOHC speed sensor since your auto will not work.also the tach from a dohc motor.
so the question is , is it worth it. not IMO. now if you have a s13 dohc that has blown in your car then a s14 long block would be ideal. also need to modify power steering to work. and a s13 dohc throttle cable. so as you can see it is a bit of a change over.
Old Jul 30, 2003 | 08:15 PM
re037's Avatar
koo koo, thnx for the info.
Old Aug 21, 2003 | 01:56 PM
Amolao's Avatar
Thumbs up How about this then..??
I would like to upgrade my 1989 manual hatch to a newer K24DE, my engine (K24E) is in good shape and low mileage but Im looking in to getting the newer and modified it for performance. Whats the newer engine I can put on my car????? I will only mod things like intake, larger pistons, shave head,etc, very basic upgrades. nothing major, just enough performance to keep the car for another 20 years.....my baby....
Old Aug 24, 2003 | 06:06 PM
s13zilvia's Avatar
poop!
S13freak
Jun 21, 2004 10:27 AM
Tempest
Feb 12, 2004 10:31 AM
spliffstar
May 9, 2003 07:42 PM
xriz
Nov 22, 2002 02:42 AM
spliffstar
Oct 7, 2002 06:23 PM
