s13 KA to s14 KA......problems?
im swapping a s13 KA (sohc) to an s14 KA (dohc). and after searching the forum and finding no answers, im trying to figure out what all changes will need to be made, i know i will have to relocate the power steering resevoir along with the lines, the ac lines will need to be relocated also (not a major concern), and other things of that nature. but my main concern is that the s14 is an internal coil and the s13 is external, what problems if any will i come across. i am using the s14 wiring harness, and s14 ecu. does the body harness plug into the same ecu as the engine harness? my theory was that since i am using the s14 wiring harness and ecu that all problems would be solved. but thats just my theory.
Im pretty sure www.heavythrottle.com will have the answers you need.
hotimportknight
01-09-2005 10:58 PM
