sputtering, bogging down engine
Old Jan 19, 2005 | 04:45 AM
jonpowell's Avatar
Z32 MAF is NOT direct compatible with the RB25
What parts did you change on the motor BEFORE installing it?
If you are idling at 2000RPM the engine is in limp mode, a couple things will cause that & the most common is MAF problems.
Throw the ECU into diagnostics mode & see what codes you get.
Old Jan 19, 2005 | 07:38 PM
bottombunk's Avatar
how many flashes do i need to make it go into diagnostic mode. in otherwords after i turn the dial to start the flashing.
Old Jan 19, 2005 | 08:05 PM
jonpowell's Avatar
Once it starts flashing, count the flashes....five & five is all clear. Anything else let me know the flashes, short & long, and I will tell you what it means.
Old Jan 26, 2005 | 05:11 PM
bottombunk's Avatar
well for starters the plugs were wrong, so who ever had the engine before me put the wrong plugs in. i of course followed suit. i got the right plugs in the timing is advanced to 15 degrees it was at 5. now it only sputters before boost. im still working on it though. if anyone has a better idea of what is wrong let me know, please.
Old Feb 19, 2005 | 06:34 AM
bottombunk's Avatar
well its back to sputtering. the mafs is not a z32 mafs. now its hardly driveable. i also rewired the mafs and soldered it again. soldered it just for completeness sake.
broke240sx
SR
May 1, 2008 08:02 PM
racedk6
Nov 25, 2006 08:05 PM
colombia
Oct 17, 2005 06:45 PM
Strizzy
Aug 26, 2003 01:15 PM
Major Mayhem
Jun 17, 2003 12:03 AM
