SR20DET - Definately NOT Impressed
Old Mar 29, 2004 | 11:58 AM
  #166
PROJECTRB240SX's Avatar
THE RB SWAP IS JUST AS EASY AS THE SR SWAP WIRING AND INSTALL INCLUDED.
Old Mar 29, 2004 | 12:03 PM
  #167
SORRY IF I'M COMING OFF AS A *****.... I JUST DON'T LIKE WHEN THE SAME TOPIC GETS BEATEN TO DEATH.
Old Mar 29, 2004 | 12:25 PM
  #168
Jyun's Avatar
Well I'm just saying what they told me, I'm not sure if its true or not anymore, but since I moved to T.N. I dont have to smog any more so I ok now.
Old Mar 29, 2004 | 12:32 PM
  #169
rkcarguy's Avatar
Ok so in generally you used the RB harness to ECU, then ran the wires needed to the cluster, and just leave the old KA car harness there and powered up, but not hooked to anything? Also used the KA cluster or RB cluster? Sorry if I'm thread jacking I'll make a new thread if needed.
Old Mar 29, 2004 | 12:40 PM
  #170
I USED THE RB20 UPPER ENGINE/ECU HARNESS AND THE LOWER KA HARNESS. I'M USING THE KA CLUSTER WITH A RB20 TACH SWAPPED IN. THE KA UPPER ENIGNE HARNESS AND ECU IS COMPLETELY REMOVED.
Old Mar 29, 2004 | 02:46 PM
  #171
well as long as you keep going with "RB is better" it's a given that there will be someone who will keep going with "SR is better" so deal with it
Old Mar 29, 2004 | 04:10 PM
  #172
This arguement can go on for forever and day!
Old Mar 29, 2004 | 05:06 PM
  #173
tegg_gsr's Avatar
SR is good and the RB sucks
Old Mar 31, 2004 | 01:04 AM
  #174
hitokiri_808's Avatar
rb mo'betta. lol
Old Mar 31, 2004 | 02:29 AM
  #175
wow I could have sworn I posted a long post here last night about RB installs... guess it got admin'd?
Old Mar 31, 2004 | 09:47 AM
  #176
I checked this thread last night, I didnt see anything
Old Mar 31, 2004 | 10:21 PM
  #177
NightXCZ77's Avatar
Get a clue or get off the boards.
Old Mar 31, 2004 | 11:34 PM
  #178
Front clip for front clip:
SR
- get front clip
- modification to wiring
- swap clusters
- can use radiator
- can use engine mounts
- can use tranny mounts
- no mod to driveshaft
- no hood cutting
- more aftermarket support (in the U.S.)
- less power stock
- less weight stock
- designed as a factory engine for the S13/S14 chassis
RB
- get front clip
- can't use radiator without modification
- can't use engine mounts without modification
- can't use tranny mount without modification
- can't use driveshaft without modification
- can't use hood without modification
- not as much aftermarket support (in the U.S.)
- more power stock
- more weight stock
- NOT designed as a factory engine for the S13/S14 chassis
Old Apr 1, 2004 | 12:29 AM
  #179
Raine...that doesnt even go for the RB20 bro.
When I was fitting my old RB20, the R32 Radiator fit fine.
Old Apr 1, 2004 | 03:33 AM
  #180
ahh... well, minus 1 then. I think that was for the 25.
