Two Problems. Window and Seatbelt
Old Jun 23, 2008 | 11:42 PM
aznkipz's Avatar
I have a 1990 S13 Hatchback. There are two problems. I tried searching on the forums but I dont know if anyones problems is same as mine. My driver side power window wont work. No sound, no nothing when I press the driver window switch. But for passenger side it works? What could that be? The seatbelt problem is that when I go in the car, the "automatic" seatbelts arent automatic at all. They do not move from there spots. Driver and Passenger side. On my gauge cluster, the seatbelt light even stays on constantly. Never seen it not on. So the driver side window switch wont work and the automatic seatbelts wont retract and the gauge cluster seatbelt light is always on. Please help me with the situation. Thanks.
Old Jun 24, 2008 | 08:55 AM
jaronervin's Avatar
For the window, replace the power window amplifier, also called the relay... it is the little black box that connects to your window switch inside the door. They are kind of expensive new, but I got mine from a U-Pull junkyard for $7.
Old Jun 24, 2008 | 03:25 PM
the seat belt ecu is known to fail, i've heard the dealership will fix or replace it for free if in fact that is the problem.
Old Jun 24, 2008 | 08:21 PM
aznkipz's Avatar
I called them today but they said for the seatbelt, it isn't free? For window, its the window amp for sure?
Old Jun 24, 2008 | 08:34 PM
i've been told by four different people that it is free. but if it's not then you could always swap the auto seat belts with the manual belts.
Old Jun 24, 2008 | 09:36 PM
jaronervin's Avatar
If you aren't hearing any sound, no clicking noises, then that would be my bet... especially if your driver switch takes the passenger window down. I had a similar problem, and the relay fixed it. I ended up replacing my switch first, and that did not solve the problem (although it solved a problem I didn't know I had: no one-touch down driver window), but when I put the new relay in, I haven't had a problem since.
Magius360
Mar 31, 2011 02:54 AM
kang128
Nov 12, 2004 04:22 PM
yiaracer
Oct 29, 2003 08:19 AM
SagxaZefiro
Sep 24, 2003 03:52 PM
Geno_110
Sep 21, 2003 05:42 PM
