almost stalling
Old Nov 3, 2003 | 12:00 AM
onevia90's Avatar
almost stalling
allright i have an s13 with a sr swap stock turbo, s15 injectors, r33 fuel pump, greddy intake manifold, apexi exhaust, blow off, hks intake and fmic, blitz sbc-id runnin 12 lbs of boost.I dont get on it much but when i do after i let of the throttle and put the clutch in the rpms drop fast, slows down around 1k then it drops down to like 300 and almost stalls and a few times it has so if anyone has had this problem or knows what it is or has any suggestions please let me know thanks
i think it might be the blow off but im not sure how you go about recirculating it
Old Nov 25, 2003 | 05:22 PM
1991s13240's Avatar
do you feel like you are making peak power up top
Old Nov 25, 2003 | 10:22 PM
s14.5boy's Avatar
Maybe a vacum/sensor problem
Old Nov 25, 2003 | 10:28 PM
Jonas's Avatar
basically, play with the idle air control screw which is on the manifold with a philips screw... try to open it up a little bit it might idle higher but it will take away your "stalling process"... and what is your boost guage vaccum reading at?? basically stock sr with few bolt ons it should be dead on 20 in-hg... andthing less you have a vaccum leak somewhere and this could be causing your "stalling" problem.. let us know
Old Nov 26, 2003 | 04:36 AM
I had that problem, but it was with my stock KA. I don't know if it would be fixed the same way. On the KA I had to clean out the throttle body, but like I said, I dunno about the SR
Old Nov 26, 2003 | 07:53 AM
Jonas's Avatar
actually now that i think about it... i know ALOT more people with this little misfit... i guess just try out what i said up above and if not... start learning how to heal toe
Old Nov 30, 2003 | 05:30 AM
ixcocoyxi's Avatar
turbo lag??
Old Nov 30, 2003 | 06:53 PM
drnovascotia's Avatar
speaking with no SR experience, this is known to happen w/ KA's as well. Check your basics, your MAFS could be clogged not sending in enough air during the recovery from gunning it, your 02 sensor could be bad, vacuum lines could be bad, throttle body could need to be cleaned.
I don't know how to verify the BOV, ask that in toe turbo forum.
Dr.
Old Dec 18, 2003 | 11:22 AM
joe3180's Avatar
one way you could fix your prob is by buying a eids from hks. it will control the idle for you....thats what i did....it should work for you
Old Dec 19, 2003 | 12:33 AM
crimsontide240's Avatar
Yep. I agree with the Doc. Don't look to find a problem with your engine or your turbo. Mine stalled just like yours is doing. Cleaned my MAF sensor...... problem never came back.
Old Aug 3, 2004 | 06:28 PM
PissonH's Avatar
with what did you clean your maf sensor
Old Aug 3, 2004 | 08:20 PM
compressed air
Old Aug 4, 2004 | 10:52 PM
sr20 learner's Avatar
sup as u guys know im a learner i jus wanted to know whats a maf?and if u clean ur maf (which i dont know yet) and prob. contines it most likely should be the 02 sensor cuz same thing happened with my freinds 240sx and at dead stop it would almost stall and then when he would give throttle in 2nd gear at lik 2500 rpm it would sound lik its not going in gear and he would have like really press the gas then it would pull in gear.The shop said it was doin that cuz the o2 sensor was messed so it couldn't sense how much air,well thats all know pretty much.
Old Aug 5, 2004 | 08:54 AM
ArticDragon's Avatar
MAF Sensor is the Mass Air Flow Sensor. it senses how much air is entering the TB and how much gas to send to the cylinders for combustion.
dubbs
Apr 10, 2007 08:32 PM
jmack240
Apr 29, 2004 08:00 AM
DrftDmn
Jun 25, 2003 09:49 PM
cjm93240sx
May 14, 2003 07:59 PM
Creamyitalian
Feb 4, 2003 08:18 PM
