Car won't start.
Old Jun 13, 2009 | 02:09 PM
brodie300's Avatar
Car won't start.
Discussion thread for Compression Test. If you would like to add a comment, click the Post Reply button.
Old Jun 13, 2009 | 02:11 PM
Nickmerrone's Avatar
I don't understand the point of this.
Old Jun 13, 2009 | 02:23 PM
brodie300's Avatar
sorry new to the site not sure
Old Jun 13, 2009 | 02:31 PM
brodie300's Avatar
but i do have a big problem with my 240 it wont start. turns but doesnt start did plugs wires cap rotor and 1ST injector because it was missing any suggestions?
Old Jun 13, 2009 | 02:57 PM
check battery, alt, fuses, starter.
Then go from there.
Old Jun 13, 2009 | 03:00 PM
some background info would help. like when it turns over, does it turn over slower than normal or about the same? obviously after a few repeated attempts it will drain the battery, but what it did initially is what i'd like to know. also, was this something that just happen out of the blue, or have there been early warning signs of a possible problem?
any further information will help isolate, and hopefully remedy the problem.
Old Jun 14, 2009 | 07:40 AM
brodie300's Avatar
Yes it would sometimes only run on three cylinders being the 1st wouldnt work. I replaced the fuel injector on the 1st cylinder and it seemed to fix it for about a week then was really hard to start ran about a block and shut off. I replaced plugs wires cap rotor fuel injector again and I get nothing. The car will turn and sounds fine just not start im confused. I thankyou in advance for any help!
Old Jun 15, 2009 | 08:13 PM
brodie300's Avatar
Now i replaced the distributer timing should be real close great spark fuel is good still wont start am I missing a fuse? a bad ground? what? any help would be awesome
Old Jun 15, 2009 | 08:26 PM
240smoke's Avatar
What about compression? Are you numbers even across all the cylinders? If you have spark, fuel, and compression, then it is timing, or a wiring issue.
redline88
Jan 17, 2006 09:31 AM
Plastic Phork
Sep 22, 2005 12:26 PM
woofywolfer
Aug 1, 2005 05:31 PM
FlyingS13
Jul 19, 2005 07:40 PM
Teh Luckinator
Jun 13, 2005 06:30 PM
