Condinsation on Lights
Old May 26, 2005 | 07:30 AM
Well, i rinsed my car off the other day and i got a little bit of water inside the left headlight. I just got done putting the new bulbs in and removing the yellow with some metal wheel polish, so if its not one thing its the other. My dad also has some in his 03 mustang. Any way to get rid of it w/o removing the headlight?
edit:
Is there a way to take the lenses out w/o taking the hole headlight out first?
Old May 27, 2005 | 07:33 AM
2fast4y0u's Avatar
good luck...easiest thing to do is use a hair dryer! yes a hair dryer. hold it pretty close to your lenses and it will evaporate any moisture inside the head light. just make sure you dont hold it one spot for to long resulting in a burn mark. make sure you get this taken care of in a timly manner because if you dont, that moisture on the inside will leave some nasty yellow that you wont be able to get off.
M374llic4
Feb 24, 2005 01:21 PM
240sx420
Jan 21, 2005 06:58 PM
NissanS14Kid
Sep 29, 2004 11:28 AM
JonBrekke082885
May 17, 2004 07:43 PM
houston
May 25, 2003 02:37 AM
