Dim Headlights~ bad electricity flow
Old Jun 23, 2005 | 06:38 PM
CowboyTurbo's Avatar
My headlights seem to be getting dimmer and dimmer these past few weeks. I'm fairly certain that it's because the electricity flow going to them is getting worse (the bulbs are pretty much new and it's not like the headlight housing is getting dramatically yellower). I'm about to go trace the wires tommorrow to check the connections but I wanted to ask you guys what else I should look for...?
Old Jun 23, 2005 | 07:13 PM
Fast1One's Avatar
Maybe your getting less juice from your battery
Old Jun 23, 2005 | 07:20 PM
Cape 240's Avatar
maybe battery ... maybe loose wires, also check the casing around the wires all the way around. There maybe a skinned off piece thats loosing power?
Did you tighten the bulbs? lol
Old Jun 23, 2005 | 10:04 PM
it's a new battery...
Old Jun 24, 2005 | 12:08 AM
BigVinnie's Avatar
You guys are all wrong after a while the lights will start to get really bright on high rev and the battery will start to go dead.....
Typical situation for a new VOLTAGE REGULATOR and 8AWG ground wire.........
Old Jun 24, 2005 | 01:12 AM
Waynehead05's Avatar
yep grounding is the culprit
Old Jun 24, 2005 | 08:40 AM
hmm... ok, ill check those two things next
Old Jun 26, 2005 | 11:21 AM
agreed with the ground wire... or if your OEM wiring is crusty old, a couple of relays and some fresh wire will really brighten up your headlights.
Old Jun 26, 2005 | 03:01 PM
thanks for the pointers fellas, it's been 95+ degrees outside these last coupla days with humidity that I could Judo Chop! so imma wait for a bit before I start workin' on it~ ill let y'all know when i find the culprit...
slcmuffinboi
Dec 4, 2005 09:24 AM
namster180
Nov 1, 2005 09:23 AM
roneosf
Oct 17, 2002 02:59 PM
Import Fanatix
Sep 24, 2002 09:17 PM
