engine noise????
Old May 17, 2006 | 08:40 AM
slimbung's Avatar
engine noise????
My car is making a wierd whining noise that follows along with the engine RPMs. Not really sure what it is or how to fix it. please help
Also the belt for the AC probably needs to be replaced cause it squeals when I first start the car then goes away a few seconds later.
Old May 17, 2006 | 09:04 AM
drf1nstyl's Avatar
do you have an aftermarket system could be feedback from the wires...
Old May 17, 2006 | 10:18 AM
slimbung's Avatar
definatly not the stereo cause the noise is coming from underneath the hood. Possibly sounds like it is coming from the power steering pump.
Old May 17, 2006 | 11:35 AM
drf1nstyl's Avatar
ahh then i have no idea sorry
Old May 17, 2006 | 05:08 PM
Dounveeme's Avatar
please be more discriptive as too where and what kind of sound
Old May 17, 2006 | 06:11 PM
my_kinda_livin's Avatar
i think i might have the same problem...when i drive, around 2500 rpms it starts whining then stops when it gets around 3000 or so. did it really bad for a while but didnt do it at all today
Old May 17, 2006 | 07:47 PM
re037's Avatar
im gonna bet on the water pump
Old May 17, 2006 | 10:40 PM
Magius360's Avatar
Yeah, its probably the water pump. The bearings in the pump making a loud squealing noise. The water pump is especially annoying to replace. If you are lucky, it may be a slipping belt. In that case, all you would need to do is tighten the belt up so that it doesn't slip.
Old May 18, 2006 | 02:04 AM
Dounveeme's Avatar
or get new belts cuz they are glazed if its been slippin awhile
Old May 18, 2006 | 07:34 AM
slimbung's Avatar
Pretty sure that it is coming from the power steering pump. Almost positive. I was listening for it and think its coming from there. It is a fairly quiet whine that follows along with the engine RPMs. Could possibly just be needing to replace the belts i believe.
Old May 21, 2006 | 12:11 PM
slimbung's Avatar
gotta an update on the car. Turns out it was my altenator that might have been making the noise. My altenator went out on me last friday and now I'm stuck without a car. Probably gonna have to get the motor rebuilt or something. The reason that the altenator went out was because the motor, which has been leaking oil pretty bad lately, had been leaking oil on the altenator which caused it to go out. SO therefore i will probably have to replace most of the seals in the motor because the front main and possibly the head gasket seals are bad along with just about all the others. Since the shop is gonna be replacing all of the seals i think i have decided to get the whole motor rebuilt and then save up for the KA24DE Greddy turbo kit afterwards
Jack0423
Feb 17, 2004 09:58 AM
target
Jan 12, 2004 11:17 PM
ricks89240
Sep 25, 2003 07:35 AM
Guam_Guy
Sep 21, 2003 05:51 PM
Elusive240RI
Aug 7, 2003 05:41 PM
