Is this a good deal? 89 240 Coupe
Old Dec 9, 2004 | 05:02 AM
moreorles's Avatar
I have been looking for a coupe and found one yesterday at a local dealer. 89 with 119,000 miles. Everything works except the air. The car is in great shape. Original paint, no rust, no dents. Interior in great shape. Fabric has no tears, burns, etc. I was told it was a one owner car owned by some guy who works at UPS. It appears to have been well taken care of. Asking price is $2200. I could probably talk him down a few hundred. Also is there anything specific I should look at, like recalled items, or known problems with this model?
Old Dec 9, 2004 | 10:35 AM
s13_peacekeeper's Avatar
if it has the heads up display check that LOOK UNDER THE CAR FOR RUST/DAMAGE alot of people dont think of this ask them if you give them 22 then will they fix the air and if they say no start at 18 but i wouldnt go over 2,000. um... other than that i cant think of anything else it sounds like a nice well taken care of car. is it a 5 speed or auto?
Old Dec 9, 2004 | 11:09 AM
moreorles's Avatar
It is a five speed. I allready asked about the air. He will not have it fixed. I will take a look for rust.
Old Dec 9, 2004 | 11:17 AM
oh and another trick, kelley blue book it, if its lower take that to them and tell them you will give them that much for the car, (excluding taxes and fees) and see what they say.
Old Dec 9, 2004 | 12:01 PM
Amolao's Avatar
Whoa! thats low mileage, good indication that is in good mechanical shape....probably, ... yes check for rust and prior accident history...no bent frames, no rust underneath.....if solid and clean I will give him 2000 dollars....the AC repair is going to run around 1000 or 1500 dollars depending of where you go, if you do it...around 700......the AC compressor get replaced MOST of the time regardless of whats wrong with it and is expensive. If you are really lucky then it might just need refrigerant, but then thats a sign of leakage and contamination so you will end up replacing the compressor sooner or later.....
good luck!
PS. where is this car at??? Im looking for a clean coupe myself....HEHEHE!!!!
Old Dec 9, 2004 | 01:32 PM
KAFREAK's Avatar
Hey man, sounds like a good deal to me. I have two 90 240's and the only problem I had with one of them is the heatsheild on the stock headers somehow got pushed up against the header and it made the annoying rattling noise but that was an easy fix. Other than that its been a great ride.
good luck
amace013
Mar 2, 2010 08:05 AM
trevr
Sep 27, 2006 09:04 AM
thisguy
Feb 15, 2006 05:16 PM
moreorles
Feb 1, 2005 04:29 PM
s13slider44
Dec 30, 2004 02:16 PM
